Axle Cleaning - Please Respond
Discussion in 'The Garage' started by mikeperez22, Oct 14, 2004.
  1. mikeperez22
    mikeperez22 Registered Member
    May 11, 2004
    41
    I am restoring a 1st Gen Blazer and I am having both axle housings powdercoated. I was going to have the housings hot tanked and then blasted before the powdercoating, but I can't find anywhere that has a hot tank large enough for a D44 or a 12-bolt. Does anyone have a good idea on how to clean the inside of the axle housings before they are put back together? Thanks.
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Are you referring to the inside of the axle tubes? The only part that needs cleaning is the seal surface (brake cleaner works for that). I would just have it sand blasted with the diff cover on and the tube ends stuffed. There is a shop here in Phoenix that will do an axle (clean/sand blast & powder coat) in any color for $75.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    At work we clean it with solvent. The rinse it with carb clean, and blow it dry. Gets it as good as new! /forums/images/graemlins/waytogo.gif You need to scrub with a brush of course.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I used a wire wheel on my 14bff, made it nice and new looking just took some work /forums/images/graemlins/thumb.gif
  5. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,496
    1,202
    So Cal.
    hello, this my first post to ck5. just wanted to give you another option. you could build a solvent tank big enough for an axle. thats what im doing, iv got several axles i need to clean, so i buoght a 60 in x 20 in dia fuel tank it had dished ends. i cut the ends off fliped them over rewelded them on so they are domed, than cut it in half length wise, cut an end off of each half, but welded to halves together. i just need to finish the stand and get a submersible pump for solvent. it wasnt that much work at all.i hope i did this post right.
  6. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Welcome! /forums/images/graemlins/peace.gif
    Guess what. We're all bringing our axles over to your house!
    /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  7. muddbudd72
    muddbudd72 Registered Member
    Dec 3, 2003
    55
    port allen louisiana
    one of those roundish toilet brushes with some kind of solvent gets the inside ot the tubes pretty clean. if its just grease on the outside oven cleaner works, removes grease and paint.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    We sure are....as soon as he fills out his profile so we know where to find him. /forums/images/graemlins/woot.gif
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Don't forget to upgrade the front axles to some newer ones. 1st gen k5's came with small Dana 30 size u-joints.
  10. rdn2blazer
    Jun 9, 2004
    16,496
    1,202
    So Cal.
    thanks for the friendly welcome,il have an axle cleaning party, you guys bring the beer! im very new to computers,so i feel like a monkey on this thing /forums/images/graemlins/ears.gif i guess i should stop in the newbie room and say hello first before i reply to any post, or does in not matter? /forums/images/graemlins/smile.gif
