axle clip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by flblazer, Jul 10, 2001.
  1. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    how do i put it back in i am goin to see how it drives hope its not bent i need to go to the :")boogs satday
    crazy k5
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, with the center pin out of the carrier you push the axles all the way inwards and then you take the c-clips and slide in the groove with the open end of the clip toward the bottom.
    Then pull the axles back out as far as they will go and re-install the center pin.
    When in doubt.....Use the Saws-all[​IMG]
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
