Axle Code- Part 2
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Nov 26, 2000.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    While looking through my afore-mentioned code book, I found out that I have a limited-slip rear diff. I seem to recall a post a while back about an additive that GM sells specifically made for limited-slip diffs. Is this lube necessary to use, or does it just offer some extra protection? If so, why is extra protection needed?
    Just curious- Do all K5s come with a limted-slip rear end?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you do need to use the additive because of the clutches that are in the limited slip unit
    s.smith 77blazer lookin 4 mud
  3. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Youn dont have to buy it from GM. Any parts store....about $7
  4. Can Can
    15,552
    136
    Once again, guys: Do all Blazers have the limited-slip rearend?
  5. Cavalry
    Oct 1, 2000
    978
    I dont think so.....had one that I believed had the original axle and no posi. I know the diferance between LSD and locking.....why does my RPO sheet say "locking diff" if its a LSD
  6. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Nope, some are open diffs, some have the gov-lock, and some have limited slip. Limited slips need additive for the clutches in them, don't know if the gov-locks have clutches.
    Fencepost eater
  7. Can Can
    15,552
    136
    I understand how the limted slip differential works, and I believe I know the concept behind an open diff, but what about the gov-lock? And why would they sell a Blazer with an open diff?
  8. Cavalry
    Oct 1, 2000
    978
    Is there 2 different codes for LSD and a locking diff? Anyone know how to tell them apart?
  9. Can Can
    15,552
    136
    The GM code for limited slip is G80. I couldn't find a separate one for the locking diff.........maybe they are the same thing?
  10. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    G80 is the code for the gov-lock. I have no idea what the code is for the LSD. If ya don't beleive me pull the cover, if it looks like a cuckoo clock in there its a gov-lock (POS, just my experience [​IMG]). My 89 S-10 Blazer had the gov-lock and a G80 code in the glovebox. Did I mention how useless it was?[​IMG]
    Rene
  11. Can Can
    15,552
    136
    Rene: My little book says the following-
    G80 AXLE POSITRACTION, LIMITED SLIP
    Man is this stuff confusing...........
  12. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Does someone have a stock LSD that is not a Gov-Lock?
    The terms "locking differential", "posi-traction" and "limited slip" are often used interchangeably. I always figured that because of this, the "LSD" axles actually had the G80 Gov-Lock.
    "They tell me that you can make it to work without big tires. I'm still not convinced."
  13. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    The only thing I can think of is if G80 is the code for a traction aiding device, whatever the device was for that year. I know my S-10 Blazer was an 89 and it had the gov-lock and G80 in the glove box. Then again you never know for sure with the 'General'. When was the last year that GM offered the clutch type limited slip?
    When I bought my 88 GMC 2WD pickup in early 89 I was told it had the "locking" differential. Again, gov-lock and a G80 code.[​IMG]
    Rene
  14. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    To the best of my knowledge, the Gov-lock (option code G80) was the only limited slip type differential offered by GM in light duty trucks since at least the early 80's. GM called the Gov-lok a "locking differential" in the literature though it definitely qualifies as a limited slip. I think the confusion stems from people using the terms locker, posi, limited slip, locking diff, Gov-Lok, etc...all to describe the same thing. I don't know how many people I've heard say they have a "locker" in their new Z-71.......trust me, the Gov-Lock does not work anywhere close as good as something like a Detroit Locker, or even a good aftermarket posi/limited slip.
    Not all Blazers/Jimmys came with the Gov-Lock since this was an option.
