Axle code
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outlaw612, Jul 10, 2001.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Does the code "RJU" make sense to anyone? It was on top of te rear axle in my 79 3/4 ton pickup
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I wanna find out what that means too....but no one seems to know of a place to get them other than a junkyard!!
    I think there would be an online place....but no one coughs up the place....
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    DOH!! I just realized that was you!! I am still looking for the code man!! I want them axles!!
    SK-15
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The only place I've ever seen those codes listed is in the Hollanders manuals. Every junkyard on the planet has a set of those manuals. GM assigned their own code to the axles, known as the RPO code. The RPO codes are the only ones I've ever found in a GM manual. However, the RPO codes are not stamped on the axle anywhere. [​IMG]
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
  5. dyeager535
    26,975
    Axle codes aren't in my Hollanders, nor are the in the Haynes manual. (although the Haynes manual for the Cutlass lists them..go figure) Not sure where else you can get that information...maybe try a local dealerships parts counter??
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Take the cover off and look at the ring gear. It'll have the number of pinion teeth, followed by the ring gear teeth. There's some numbers before that, but at the end of the sequence it'll have it.
    Mine says XXXX 10 41, which if you divide out 41/10, you get 4.10.
    Tim
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Wish I could remeber the book that I seen them in, it was in the public libeary, and if I rember right it was for
    cars and not trucks.
    Good luck
  8. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    After about 15 min of searching by the dealer in my area they came up and told me that they are 3.73 gear ratio.
    SK-15
