Axle forward? yes-no??
Discussion in 'The Garage' started by owen, Nov 18, 2005.
  1. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    I have the 52" swap under the front, with a flip and zero rate in the rear (the rear is still centered). I am takingthe truck to a shop to have the fenders stretched rather than cut, so I need the axle in the right location when I take it. I have a set of 38.5's I am trying to squeeze without lifting the truck to the heavens. Should I slide (with zero rate) the axles to the max position in the front and rear? Are there any drawbacks to this? HELP
  2. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    going to the body shop monday.....
  3. dremu
    Feb 27, 2000
    15,966
    457
    East of San Francisco
    Shifting the rear axle back can cause your rear diff to want to become one with the gas tank... at least on vehicles with a rear center tank, a la stock K5's. Pickemups with the saddle tanks and bed-mounted fuel cells get around this.
    Shifting the front axle forward is a very good thing. You need to do crossover, then, but you move the tires away from the firewall ... you can do whatever you want to the wheel wells, but that firewall is a big blocker to wheel travel :D Unless you're Steve "Mine Is Smaller" Fox :haha:
    Anyway, I'd say maybe move your rear axle back, depending on the gas tank sitch, but definitely scoot the front forward. The increased approach angle alone is worthwhile, plus you can fit bigger meats at full stuff without whacking the firewall.
    You're taking your truck to a *body shop* to have them do the wheel wells? You must not wheel where you're worried about denting!
    -- A
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i think id keep the rear stock location, and move the front forward. moveing moving the rear will force you to do alot more stuff to the rear fenders as well. the front isnt that big of a deal.
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    You can move the rear axle rearward 2.5" before you need to worry about the gas tank. You can move the front axle as far forward as you want depending on what you're going to do about a core support. The furthest you can move it forward with 52" springs (26" center) is 4.5" without extending the frame.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Ditto.
  7. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    To me, a dent is something unavoidable- it happens in the act of wheeling. Having a jagged edge around your fender is avoidable, and I want to keep a factory lip. No offense to those who have trimmed- it is just my thing.
    I do have rear steer/crossover so I am going to try to scoot it forward another inch. I will also take the rear back 2.5 as suggested. Thanks for the helpful advice.
