Axle/Gear question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Muddytazz, Jul 9, 2002.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I am running a D44 in the front and 12 bolt in the rear that are semi float in a 75 K10 Suburban, they are stock with the stock 3.08 gears...I am wanting to change the gears to 4.10's....anyways, the question i have is, I want to put full float axles in, do they make full float for 1/2 tons?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i think there's a kit for the 10 bolt and the 12 bolt to convert them to FF. not sure though.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Yes, I believe you can get a kit from ORD to make the 12 bolt a full floater. I personally think that you would be better off to find a 14 bolt with 4.10 gears and just swap it in. You would get more strength, full floating design, and the gears you want.....plus it would be cheaper. Either convert the front to 8 lug, or replace it too. Another option is to find a SemiFloating 14 bolt out of a light duty 3/4 ton.....it will be 6 lug.
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i have a dana 44 6 lug 4.10 for 200 bucks...
    cheaper to buy used axlesthan pay 500 for gears and install...
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
