Axle / Gear ratio Question
Discussion in 'The Garage' started by ntx78k5, Apr 29, 2005.
  1. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    78K5 350 TH350 with I believe the 208 Full time 4x4 transfer case. I have a 4" lift and 35 mud terrains.
    I have 342 Gears and as you can imagine, Its a dog on the road and in the wind. Does great in the mud and the trails, never had it on the rocks nor do I plan on it.
    Is it cheaper to upgrade to used 3/4 or 1 ton axle's with a better ratio or should I just upgrade what I have to 4:11's? I've checked on the gear swap and for both its around $1500-$1800 from the shops i've found in the DFW area.
    I know used axle's can be a risk but what should I look for ?
    Thanks for any advise.
  2. grape
    grape Registered Member
    Mar 10, 2005
    27
    texas
    i'm in the area, can do the gear swap for half that including parts and make good money. That's a rediculous price. Labor is usually 200 per end....doing both ends somebody should charge 300 total for 150 per end, plus parts. that's robbery
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    1 tons are expensive and unless you are going with less than a 38" or do rock crawling (which you said you don't), don't bother. It is viable to switch to 3/4 ton axles with 4.10, they are easy to find and cheap. Just replace the normal stuff (ball joints, etc) and switch to 8 lug wheels. BTW, you have a 203 t-case and you really should change gears, high gears with big tires destroys automatic transmission.
  4. 1977k5
    May 26, 2003
    9,996
    134
    R&P usually run ~$200, Bearings and seals ~$100 and the average labor I have seen is $3-400 per axle. That puts it at $1200-1400, which is pretty expensive. If you take it to a 4WD shop they want a lot to change gears. I have always done my own, though. :D
  5. grape
    Mar 10, 2005
    27
    texas
    i'm in the wrong business, all the gear swaps i've seen charged for on cars is 150-200 and people bitch about that labor charge. Not to mention the look on the guys face at most places when you ask to see their case spreader for doing Dana corp rear ends and they want to charge 400 bucks, no thanks with some monkey beating the carrier shims in with a hammer.
  6. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    If I go to 4:11 what are parts costs ?
  7. grape
    Mar 10, 2005
    27
    texas
    usually a yukon gear set is 150-180 and an install kit with all bearings seals and shims is under or right at $100.
  8. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
  9. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    Grape
    Anyone know how to contact this guy Grape. I am ready to get the gears swapped out and was hoping to reach this guy.
  10. grape
    Mar 10, 2005
    27
    texas
    sorry, I've been super busy, I'm going to send you an e-mail tonight.
