Axle gear ratio # w/o removing the dif cover and looking in glove box?
Discussion in 'The Garage' started by 88K5Jimmy, Feb 7, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Are there any numbers stamped on the outside of the axle that you can get and run them someplace to see what gear ratio they have in them?
  2. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    Re: Axle number identification?
    From the factory there is a metal tag held on by one of the diff cover bolts. The ratio will appear like this: 3 73 for 3.73. There is no decimal. You could also check the RPO's listed in the glovebox. I think they have been posted before.
    Found it.
    GU2 = 2.73
    GU4 = 3.08
    GU6 = 3.42
    GT4 = 3.73
    GT5 or GT8 = 4.10
    G80 = Gov-lock
    These are courtesy of HarryH3 in a previous post.
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    My 88 didn't have one of these tags and I can say with 99% certainty the dif covers were never opened before I changed it. Did they only do this on specific years? Also, I'm wondering if there are numbers stamped on the axle tube or housing itself that would identify a gear ratio and a place to run the number to see what they mean?
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Just take the diff cover off........
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    jack up the rear and turn the tire one full turn and count how many times the driveline makes a full turn lets say one turn of the tire and drive line turns 3 full turns and then 3/4 more turn=3:73 4 1/4 turns=4:10's 3 1/4 turns=3:08's you get the idea /forums/images/graemlins/smile.gif
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    oh yea, didnt think abuot that lol.
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    So you had the cover off and didn't check the numbers stamped on the edge of the ring gear? The BOM numbers on the axle tube won't tell you much, the ratio could have been changed by a previous owner...
    The most reliable way to find the ratio is to remove the cover and get the numbers off the ring gear itself. It's 10 small bolts and a few minutes of your time to know for sure...
    rene
  8. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Should have made myself more clear, my fault. I know what the gear ratio of my K5 is, I was wondering if there was any way to get the gear ratio off of an axle in a junk yard by running numbers on the axle itself and without having to pop the cover(if the axle is still under the truck and not spilling gear oil everywhere).
