Axle Help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cinchjeancowboy, Jan 7, 2004.
  1. cinchjeancowboy
    cinchjeancowboy Registered Member
    Dec 7, 2003
    10
    North East Texas
    I have 10 bolts on my Burban and have a 14 bolt FF in the barn for the rear of it. My Question is their a kit that will turn the 10 bolt 6 lug in to a 8 lug so I can run the same rims front and rear and not have to get a whole new front axle? I think the Rear I have to run 16.5"s Rim
    /forums/images/graemlins/ears.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    No, there is no SAID kit you can buy to my knowledge, just go to a yard (or post up in the wanted section) for 8 lug outers to convert 6 lug to 8 lug. Basically you need everything from the knuckles out /forums/images/graemlins/thumb.gif
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    OK, here we go... What is your current gear ratio? Gear ratio in the 14BFF? If they are the same then I am not to sure where to get 8 lug parts new but I bet you could get them at the wrecking yard. If the gear ratios differ then you are time and money ahead to just sell your current 6 lugger and go buy a 3/4ton 8 lug front with matching gears.
    Read the "14BFF in my 87'" post in the garage, it's the same question.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I am assuming that they do, but make sure the gears match....
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Here is the CK5 tech article on the 6 to 8-lug swap.....it lists all of the parts you need and the steps to do it. /forums/images/graemlins/thumb.gif
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    15's clear the rear fine. It is the front that you need to clearence (read grinding)
  7. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Hey CinchJeanCowboy, it's Corey from PS.com. Check with Maddram and the Beast, they can probably get you what you need. Maddram pulled a couple sets for some of the other guys.
    Corey /forums/images/graemlins/thumb.gif
  8. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Corey:
    Hows your project coming along? Also about what is the going price you've seen for the 8-lug outters, about $200 seems to be normal...
  9. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    That isn't bad. Kind of depends what the junkyard charged. I've seen some as cheap as $125.
    Projects coming slowly. Got my axles apart and am in the process of rebilding them. Got my ORD shackle flip. Need to get some springs and steering stuff.
  10. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    As others have said, there is no kit you can buy. You can go to the junkyard, or if you are lazy, post it in the want section on this forum. Thats what I did, and had replies within a day or two. I paid $200 for my conversion parts from a member on here, I dont remember who it was, but I think he said he gets them regularly.
    -Harrison
  11. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    normally i would just keep it to myself to have inc ase, but Ive a 8lug 10bolt wiht 4.10s i might be selling in the next few weeks. letme know.
