axle ID
Discussion in 'The Garage' started by stizkidz, May 4, 2005.
  1. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    I consider myself being fairly decent at IDing axles but this one I am just stumped on. I guess my biggest question would be: Which axles had kingpins? The axle I saw has 10 bolts on the diff and has kingpins. I do not think it is a Dana 60 though. Could it be an Eaton?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    D60 has 10 bolts on the diff cover and has kingpins
  3. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    old one??
    Its might be an early "closed knuckle" front axle ,they used them til about 1970 ..if it had a big "ball" looking thing where you see a U-joint on a dana 44 or 10 bolt corperate axle,thats what it is--real early napco axles used in the 50's had a similar setup,but differ from the later ones in the 60's..the "closed knuckle " ones use tapered bearings similar to the front wheel bearings on the kingpins..
    .They are considered a bit weaker than a dana 44 "open knuckle" axle--though I've put a few thru some abuse and had no problems at all,in fact I liked the fact the U-joints were swimming in 90w gear oil constantly,I never had to change one at all,same with the bearings on the kingpins...I guess they dont hold up as well off road if you get them airborne compared to the others,but I had heavy plows on my trucks,nothing bad happenned to my trucks... :crazy:
  4. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    as listed above. but 10 bolt is not offered that early as in 10 bolt corp. if its a 60 frt the ujoint size is unmistakable to the eyes.
  5. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    the size of the lockinghub is another thing you can't miss..
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    and the d60 uses 3 u-bolts and 2 regular bolts
  7. stizkidz
    Nov 11, 2004
    219
    The axle in question is on the front of a 68 Chevy 4x4. This leads me to believe that it is the Napco axle as decribed above. Thanks for helping me ID this. Now that I am sure it isn;t a Dana 60, I will pass on buying this one.
  8. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    not a napco!
    The Napco axles only were used in 56-59 GM trucks converted to 4x4 by Napco!--the other closed knuckles from1960-70 I'm not positive about,they are either dana,spicer,or perhaps rockwell or GM's own axle...never researched them too deeply...someone else here must know!... :crazy:
  9. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Napco did conversions after '59.... but most are 1-ton or heavier. I've seen some pics of 67-72 trucks using an Eaton based axle up front.
  10. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    If the diff cover is perfectly round like a big salad bowl, its a Napco front axle. Actually based on a modified Eaton rear axle, it has closed knuckles, kingpins, and birfield-style axle joints.
    However I'm just guessing its a stock 1/2 or 3/4 ton 4x4, which would have a D44-5f with closed knuckles and drum brakes. These suck under load, but are fine for DD.
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    correction... 3 u-bolts and 2 studs.
    j
  12. readymix
    May 30, 2004
    6,706
    26
    Mine has 3 u-bolts and two regular bolts....no studs.
  13. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Be careful, both of these descriptions can apply to a D60 or a Dodge D44. Typically the Dodge will have studs but of course a threaded hole will accept either fastener.
