Axle info & opinions needed
Discussion in 'The Garage' started by nvrenuf, Jun 19, 2003.
  1. nvrenuf
    Jan 7, 2002
    Mobile, Al.
    I have a friend that is searching for 1 ton stuff. He has found a set that has a D60 and an Eaton axle, both w/ 4.56's.
    My question; is the Eaton worth getting? Will it be hard to find parts for?
    The seller is telling him he installed a Detroit from a 14 bolt into the Eaton using the 14 bolt axles, possible? This part sounds like b/s to me but I'm not familiar with the axle so I don't know if it's possible.
    Any help and info is greatly appreciated!!
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    BC Canada
    It may well be possible... the Eaton and 14FF diff cases are very similar. I haven't actually torn one of each apart to see what swaps over and what doesn't.
    The axle shafts are within 1/2" or so. The 14FF shafts may fit directly, or require slight trimming.
    If this guy has actually done this, I'm sure he won't mind popping out a shaft to show its 30-spline instead of 17.
    4.57 is the most common ratio for that Eaton. Might be hard to get new parts, but a nearly endless supply of used center sections out there.
  3. Don
    Don 1/2 ton status
    May 30, 2002
    Spokane Washington
    yes the Detroit out of the 14 Bolt will fit right in the carrier of the Eaton, all is the same except the spline count. Just use the 14 bolt axle shaft's.
    I am doing this only in Reverse, swapping the Detroit out of an Eaton, and putting it in a 14 Bolt, just gonna use the Eaton Axle shaft's.
