Axle install
Discussion in 'The Garage' started by SUB-ZERO, Oct 15, 2004.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Have a 85 and just got a 14 bolt ff and looking at a 60 front.What do I need to look for in a 60 front and what do I have to change to install the 14 bolt and the 60? Will my current springs,driveshafts and steering work?
  2. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I know you want a 1985 or later D60 front. Any earlier than that the axle shafts narrowed down. Or, if it is older verify they aren't the narrowed axle shafts. /forums/images/graemlins/thumb.gif
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    So all other dana 60 fronts are crap? I guess I might as well toss my '78 in the trash... /forums/images/graemlins/rolleyes.gif
    any good dana 60 is a good dana 60. you can buy replacements from spicer with non-neckdown shafts for not that much money.
    The dana 60 will bolt right up to your springs, but I am not sure about the driveline ujoints or steering links.
  4. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    What about the 14 bolt going into the 10 bolt spot?Direct bolt in?what about the driveshaft and brakes? Does anybody know about the 60 in front(steering and such that is)?
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    your going to need an conversion u-joint for the 14ff. I dont know the part number. Brake are the same not sure about the E-brake. and you'll need new u-bolts.
    Is the 14FF out of an 3/4 ton or 1 ton? If it's an 1 ton your going to need to move the spring perches and shock mounts. 3/4 ton will bolt in with out any Modification.
  6. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Do you know about the 60?
  7. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    It will bolt in. the brake lines will work if your existing axle is an 10b IIRC.
    Not sure about the steering.
  8. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Thanks for the info.
