axle leakage
Discussion in 'The Garage' started by Bhintz, Jul 16, 2003.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    went outside today and found the gear lube leak out were the axle goes into the axle tube on the driver side and its a pretty steady drip, what cause this? I just had it in 4wp and it didnt do it before but now it is, and the problem w/ that is what they did was put on extend brakes and new calipers but they had to grind the calipers b/c w/ 3/4ton axles u cant run 15 rims w/out grinding the caliper which you already know, so they didnt warrenty it.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    is it a 14 bolt? if it is and they did the disc brake swap, then they might have damaged a seal or upset one and its now leaking??
  3. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    its the front 10 bolt sorry
  4. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Are you sure it's gear lube? The front 10 bolt shouldn't have gear lube out at the hub; it's not full floating like your rear is.
    Could it be brake fluid dripping down?
    Thomas.
  5. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    is gea lube and front 10bolts are fullfloating and its not coming out of the hub its coming out were the axle goes into the axle tub. i think its a busted axle seal
  6. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Oh, I see. Then yes, I would agree. It is most likely the axle seal allowing gear lube to travel down the tube.
    By full float, I meant there shouldn't be any gear oil in the tubes themselves. you're right though, the axle shafts are full floating in the 10B .... sorry for my confusion /forums/images/graemlins/wink.gif
    Thomas.
