Axle leaking how to fix?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Toad, Apr 1, 2001.
  1. Toad
    Toad 1/2 ton status
    Mar 15, 2000
    157
    Utah
    I have a 12bolt rear end and it is leaking between the axle tube and the pumkin. What do I need to do to repair this?
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The only way I know of is to have it welded. If you have the tubes welded to the pumkin it will also make it stronger.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  3. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    it's actually coming through the joint between the axle tube and the pumpkin????? Thats very odd. If you do weld it remember that the pumking is cast and you will have to heat it up before welding it to the tube. - Doug
    Doug Krebs
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I've always heard it will be weaker because the axle loses its temper when you heat it up.
    90K5
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You're right, but ya gotta do what ya gotta. Your not heating a whole lot, just a small area. Just don't poor water on it like an idiot after you weld it because it will make it worse. When they temper metal they heat it, drop it in water, than heat it a little less than before (it will reach a certain color at the desired temp). This way tempered metal is strong, yet flexible.
