Axle modification for caster
Discussion in 'The Garage' started by Mastiff, Jan 23, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Suppose I want toget my caster right AND have my pinion angle just right on my front end. Would this be done by cutting off the knuckles and putting them on at the right angle, or by rotating the housing itself relatiuve to the tubes? How big a job is it (in $) if I find a shop to do it for me?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I think it would be better to have the tubes turned in the center section. The tubes have 2 welds on them If you look at the center section, where the tubes go in, There are 2 holes per side. This is were the factory welds after the tubes are pushed in. A competent welding shop can remove that. Then the tubes will (with force) slide out. Then the tubes can be re aligned and welded back up. The trick is Finding someone that can do it. Look for race car fabricaters that have had experiance narrowing axels. They can usually do it. When i had the 12 bolt narrowed for my race car, they had a jig that lined the tube ends back up before they welded it.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I should take a 12 bolt and a dana 44 I have laying around over to the shop and see what we come up with. Get another Blazer and I could have a 12 bolt, front and rear /forums/images/graemlins/smile.gif. I've been considering building a 14 bolt front axle out of a ford D60.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well I dont know about reindexing the centersection but..I am getting knuckles put on an axle and the shop we go to said the can do it between $300 and $350, thats with cutting the spindles off the axle and puttin gthe knuckles on. Hope that hepls. /forums/images/graemlins/thumb.gif
