axle noise
Discussion in 'The Garage' started by pjsblazer, Apr 24, 2004.
  1. pjsblazer
    pjsblazer Newbie
    Apr 24, 2004
    Reno,Nevada
    I,ve got kinda of a womp-womp-womp sound at 65 and faster,78 K5 12bolt rear,203 case, already replaced frt& rear drivshfts,new mts frt&rear,changing tires didn't make a difference. someone told me,might be a pinion bearing.any ideas?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Could be , it won't hurt to check it. Grab the yoke and see if there is any play, mine was loose once after I sourced my 12 bolt, had to tighten it up only. Now of course just replacing shafts etc like you mentioned won't make any difference if the angles are wrong. Does this have any lift? /forums/images/graemlins/k5.gif
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    A womp womp womp sounds to me like a tire problem, especially at higher speeds.
  4. pjsblazer
    pjsblazer Newbie
    Apr 24, 2004
    Reno,Nevada
    Thanks, I'll check the yoke this morning. trucks not lifted,yet. I've swapped tires a couble of times. even putting on P235/75-15 street tires,didn't change.I know the noise is kinda hard to explain in print. this as been driving me crazy for about a year, now the t-case shifter is buzzing at the same time the noise kicks in.
