axle paint, what to use?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevBlazin, Mar 20, 2002.
  1. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    What is a good durable paint for axles? Is there any prep work I should do aside from wire brushing and de-greasing them. I know some paint like some types of Rustoleum specificaly says not to use any primer. All I want is a black gloss or semi-gloss paint. Any pointers?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I used basic semi-gloss black. about 3 coats and I'm calling it good.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I like epxoy-based paints for stuff under my rig. When i do my ff14b and D60, I am gonna use some gloss black epxoy-based "appliance" paint. Various brands are available and its the kinda stuff that doesnt require primer or multiple coats... just spray it on and go. Supposed to be very durable too,
    J
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I just blasted, primed and painted mine! First I sand blasted the parts, then after blowing them off, I put on 2 coats of epoxy primer, waited 1 hour, then put on 2 coats of Urathane !!(enamal works well I just had the Urathane) No hand sanding, I hate to sand so this is easy and fast and durable!!
  5. Storm Trooper
    Nov 24, 2000
    4,640
    I like the engine enamel like VHT. It covers really good, holds up and is cheap and easy to touch up. I did the whole underside of my truck in it.
  6. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I just used some cheap flat black enamel. Prepped the axle well, and put on four to five light coats. Have run it through mud and up, over, and across rocks w/ no ill effects.
  7. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i took a grinder to get all the dirt off, but use a wire brush wheel
    then i used regular rustoleum... 2 coats is thick enough but can always go w/ 3
  8. mudgrip
    mudgrip Registered Member
    Nov 22, 2001
    22
    Newport, Oregon
    I use chassis paint. You don't have to reduce it and you don't need to spray primer first. Just pour it into a paint gun and spray away. You can get it at any automotive paint store and its cheap.
  9. ChevBlazin
    Feb 4, 2002
    332
    Thanks for the replys, I think I'm just gonna go the Rustoleum enamel way.
  10. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Prep work, after you wire wheel it, clean it with acetone. Then after...........after the acetone is completely gone and evaporated, use a blowtorch to heat/dry the metal as you go along and paint. Yep, you will actually see the moisture leave the metal as you heat it. Then the paint will stick reallly well............
  11. jimyjamm
    jimyjamm Newbie
    Mar 19, 2002
    3
    go to www.porstore.com this stuff is pretty cool it's a rust preventive/destroyer that is brushed on it comes in clear, glossy black,or semi gloss black it cures to a bulletproof armor that is pretty impressive. it's called POR 15
  12. Parf
    Parf Registered Member
    Nov 16, 2001
    81
    Golden, Colorado
    I heard that Spray can Enamel Appliance Paint is the way to go with diffs. Its used for stoves or 'fridges, etc... A HARD drying paint thats easy to clean, and tough, and....cheap. Problem is that it only comes in Black, White, and Cream colors. Black sounds good to me. A can of Easy-Off, and away we go!
  13. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> POR fades in sunlight so you'll need their new protected UV coating as well.
  14. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    its ok that appliance paint only comes in black... no other color should be visible under your rig anyway! /forums/images/icons/tongue.gif
    J
  15. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Here's a photo of what I did:
    http://imagep.webphotos.iwon.com//1000016899/1000016899_321200285222AM0.2681238.jpg
    I first got after it with some degreaser. After it dried, I sandblasted everything to bare metal (Sears has a portable unit for $60, and you can get one on ebay for $24. Use with your air compressor). Then I sprayed it with Rustoleum primer, then flat black Rustoleum Paint. Look at the picture and decide if you like the results.
    Good Luck,
    Scott.
