axle painting
Discussion in 'The Garage' started by TXsizeK5, Feb 27, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Hey what did you guys do to prep and paint your axles? Thanks!
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    wire wheel and rattle can
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Same here. Wheel on a 5" angle grinder, and some Krylon Rust Tough paint. After I install it I will coat it with 'Dirty PS Fluid' and 'Grungy Valvoline'; you know, for that 'finished' look.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    same here, except I use a wire brush instead of a wheel.
  5. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    a long time with the wire wheel, all the prep for por 15, and two coats of glossy black por 15 paint.
  6. 96chevysfa
    Jan 1, 2003
    230
    so cal
    another axle i painted, this one i sand blasted totally, and sprayed with primer, and then two coats of clat black engine paint.
    before
    after
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've used the wire wheel in the past. It takes a long time... The last one I did I sandblasted. It's messy, but does a much better job in a much shorter time. /forums/images/graemlins/thumb.gif For paint I used gloss black Rustoleum. It cleans up a bit nicer than flat finishes. /forums/images/graemlins/cool.gif
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Wire wheel and gloss black, I agree that the gloss cleans up a bit better. </font>
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    For the rear I just pressure washed and then used a wire wheel on a 4 1/2" angle grinder like already mentioned.WEAR SAFETY GLASSES!
    For my D60, I'm pressure washing it, then taking it down to bare housing, hot tanking it, then painting it with several coats of universal black or glossy black engine enamel, then building it. I'm taking each part like the knuckles, hubs, caliper backing plates, and beadblasting them at work before i paint em.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  10. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    You know that if this thread were anywhere else but here..............there would be replies like.
    Sandblast the 10 bolt housing.
    Grind all the welds smooth.
    Bondo all imperfections.
    Spray primer.
    Spray pink basecoat.
    Wet sand.
    Spray neon green basecoat.
    Wet sand
    Spray yellow basecoat.
    Wet sand
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Apply pinstriping and stickers.
    Wet sand
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Spray clearcoat.
    Wet sand.
    Paint mural on cheap chrome cover.
    Wax.
    Buff.
    Wax.
    Buff.
    Wax.
    Buff.
    Wax.
    Buff.
    Wax.
    Buff.
    Wax.
    Buff.
    Wax.
    Buff.
    Wax.
    Buff.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  11. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    after i wire wheel,sand,and prep - i use bbq black spray
    paint and on top i use satin black.
    it cleans well.
    actually, i use it in the fender wells and undercarriage,
    it looks good /forums/images/graemlins/thumb.gif
  12. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    sandblaster,prep and por 15 paint /forums/images/graemlins/thumb.gif
  13. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i just painted my diff cover, yoke, and driveshaft red. now that looks different!!
    I painted over the nasty chrome "tape" i had on the driveshaft before.
    for the yoke i did this. drill press gring/cutting attachment got all paint off. STIFF wire brush/wheel on remaing paint and textured surface. couple days later i got around to painting it. i drenched the yoke in lighter fluid, wiped clean. drenched again, lit. i uses a WD40 blow torch to finish torching stubborn dirt. wiped clean. dried thouroughly. advance auto red enamel. 8 coats or so. i just kept repeating on the d-shaft, yoke and diff cover till the can ran out/forums/images/graemlins/grin.gif
  14. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    por 15 for me /forums/images/graemlins/grin.gif
  15. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I am bead blasting each Dana 60 part with a glass bead medium (makes the parts look like alumnium when done)
    then painting them with gloss black rustoleum. I have used primer in the past then gloss black over, but I figured
    out if holds up a lot better with out primer. Rustoleum is made to be on bare metal. I was kinda pissed after I
    spent a couple hours preping and painting my front 10 Bolt just to have it come off when I power washed it. /forums/images/graemlins/mad.gif
    So from now on I dont use primer. But this time with the Dana 60 Iam going to do it RIGHT. Hopefully it will look
    better then new when I am done. Later
    -fLeXy K20
  16. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Good to know about the Rustoleum^^
  17. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i got mine painted red, 12 bolt, looks kinda cool with the chorme diff cover i put on there, one thing i would think of when doing this, if i was going black i might think of putting some bed liner on the axle housing, it might look kidna cool to me. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  18. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    you paint those things... /forums/images/graemlins/grin.gif
  19. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    lol, i figured I might as well make it look nice for now. Im thinking of painting the cover red... but screw it all I bought was black Krylon lol.
    I'm gunna be usin a wire wheel on em monday, any tips/tricks? Should I spray it down with some brake cleaner/degreaser/wd40 etc, first?
    PS. where do i get clear coat from(mechanic buddy recomended to put some on)? Can I get from autozone, o rielys?
  20. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
