Axle perch location
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DukeBoy88, Nov 22, 2002.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I'm rebuilding a 14-bolt from an 84 crew cab with CL to CL distance of 40" between axle perchs. what is the CL to CL distance between the perchs of an '88 GMC K5? My plan is to mock up the axle in place, and rotate it so it aligns with the driveshaft, tighten the u-bolts and place the weight of the vehicle on the axle, make adjustments and tack weld the perchs in place and then take it to the welding shop and have them finish it. Anyone see any problems with this method. thanks in advance.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    For a K5 you want 42.5" CL to CL
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    42.5" center to center of leaf packs is what is needed,
    40" was 1 ton all years and 4x4 before 73
    just to help verify*
