Axle perches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Nov 26, 2001.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I was wondering if axle perches are available from the dealer or do most of you make your own? I replaced my busted shim block tonite and found out why it broke, the perch is very worn out. Bent and rusty they are actually not flat anymore. So, I guess I am going to be replacing them in the spring.
    Thx
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I saw some at 4WP when I was there a week ago. You can also make your own out of square tubing (stronger and you can add some lift if you want).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    I can set you up with a set of heavy duty perches for $40.00 a pair.
    <font color=green>Steve Frisbie</font color=green>
    <a target="_blank" href=http://www.mooffroadoutfitters.rockcrawler.com>www.mooffroadoutfitters.rockcrawler.com</a>
  4. Thumper
    1,582
    Alberta Canada
    Hmmm back to the original problem. By the time a set of $40.00 axle perches get here to Canada, they have cost me dang near 120.00. Sorry Steve F. but I gotta find some closer to home. I was kinda hopin GM can stock em for a reasonable price.
    Mike
    85 Fullsize Jimmy
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Didn't Rene' make some for somebody? You might want to check with him...[​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  6. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Sorry Thumper but no go from GM, part of axle assy...
    Jim
    88 5.7 5in lift 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff
  7. AngusF
    AngusF Registered Member
    Nov 18, 2001
    7
    Edmonton, Alberta, Canada
    Why not make a set? With a 3" hole saw, a drill, a saw, and a welder, you'd be able to make some up in an hour, for just a couple bucks!
  8. Blazin Obsession
    Blazin Obsession Registered Member
    Sep 25, 2001
    64
    B.C Canada
    They are available at most 4x4 shops and some shops offer to make stronger ones if you require, I inquired about this recently and was told about $75 installed at a spring shop.
    Ken
    <a target="_blank" href=http://www.blazinobsession.com/>http://www.blazinobsession.com/</a>
