axle pull advice needed (update-he aint got the balls)
Discussion in 'The Garage' started by ducttape114, Oct 28, 2003.
  1. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    the head of the auto department at my school is building a "stump puller". he wants to pull against me. normaly i would say no but this guy is a cocky a$$hole and would really enjoy puting him in his place. hes got a late 80s F-150. 351/some auto tranny/borg warner POS Tcase/ 5.36s in stock axles/35" ATs. ive got 6.5l diesel/th350/doubler/ 14ff detroit, 3/4 ton 10bolt open/37 MTRs. i really dont think i should have any problames as long as he agrees to let me carry some extra weight. if not his lard ass ford is gonna pull me all over the place. also, he ussually builds drag cars so i dont think he has any consept of throttle control. the thing am really wondering is should i run smaller tires? if i keep the 37s i can air down way low(bead locks) but running a smaller tire would means lower gears. what do ya think? any advice?
    <font color="red"> after seeing my truck and looking at the drive train he deciced that he didnt want to go. pussy. he did however say that he would still go if he was aloud to use his half million doller front end loader. he said it with his cocky bastered attitude to, like he was gonna prove somthing by making me not pull against his 10 ton tractor. what ever. i still feel pretty good /forums/images/graemlins/grin.gif</font>
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Re: axle pull advice needed
    What gears do you have? I would air down and put it in double low, and drag the ford around.
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Never mind about the gears, i see your running 4.10's.
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    If you have a doubler and a diesel, you should have no problem. A diesel itself makes a ton of low end torque. And even if that isnt enough, that doubler will spank him. I agree with what was said before, put it in double low and pull him across the country. /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
    -Harrison
  5. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    See if he cares where you attach the cable.....
    The higher on your truck you can mount it the better. My theory is that as you start pulling against each other, the forces will be pulling DOWN as well as straight back. Maybe you can get yourself a little extra tire traction this way???
    Seems like these contests are all about traction and gearing......low gearing is good, but if he YANKS ya' before your tires can really dig in well, it won't matter what your crawl ratio is......
    Oh, fill your tires with water too (more sneaky ideas!) that should get the weight down low.... wear like 3 or 4 sweatshirts too, and wear two pairs of socks. Have a big breakfast.
    /forums/images/graemlins/thinking.gif
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Use the doubler, once you have him rolling backward's, nail it, he'll be sending up a smoke show anyhow, then drag him around on a tour of the neighborhood. /forums/images/graemlins/grin.gif
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    just make sure you have it hooked up higher on yours then his... you should be able to drag him and you really think he is heavyer then you? how many gallon tank do you have? make sure you fill up before you pull (add's a good amount of weight) I would stay with the 37's and air down a little if you have really good brakes and the guy is cocky sometime you can hold your brakes and when he starts to spin then go... so hes spinning and your pulling /forums/images/graemlins/thumb.gif
  8. Re: axle pull advice needed
    Have a full tank of gas and have a few 'joy riders' in the back to help with the weight issue. Don't spin your tires, you'll lose traction. But do wait until he starts spinning and bouncing, then you'll have the advantage.
  9. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    ok, so im gonna fill the tires with water, fill my tank up with diesel, with my tool box up with lead, and fill my truck up with friends. the highest thing i could attach to would be the main hoop of my roll cage at the top of the cab. but if i started to get sideways that might flip me over. maybe i should build a tower like the wake boarding boats use /forums/images/graemlins/grin.gif
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Weight and traction is one thing, but I hope your driveshafts, u-joints, and front 10bolt can take the abuse. Mine didn't, snapped my rear stock shaft in 2 last time I pulled.
  11. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    When I was a kid I use to do this with my 67 chevy 2wd truck most of the time who ever started to spin thier tires first lost. Mabe you will be luck if he is a drag racer and he will be hevy on the skiny pedal from the start. I wouldnt have any more poeple in the truck then he does dont want him to have an excuse for lossing.
  12. Re: axle pull advice needed
    "I even had all these people in my truck and STILL had enough power to out-pull you!" /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  13. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    it's ALL about weight.
    yeah, the PSD won. the dodge has a 525 chevy with 800horses. it has boggers on sand. the PSD is stock, with stock tires and gears. so watch out.
    YES, i HATE that picture.
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    thats a crazy truck. I have seen it in fourwheeler. oh and that ford looks like it has a lift and 33's. I still don't believe the ford won because the dodge is heavier with rockwells, huge tires, big block,huge NP200 cast iron transfer case,etc.
  15. Re: axle pull advice needed
    Are either of the trucks lifted with blocks? They'll cause wheel hop.
  16. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ]That would totally suck to build a truck like that and get beat by a P.O.S FURD
  17. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Hmmm, I think you can take him but what out, you don't want to break stuff. That always sucks! I think your 14b if up to the abuse but the front 10b might not like it. At least its open!
  18. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    YES!!!! HIS IS!!! i forgot about that. its got about 4" blocks in there. i cant tell to many details cuz i only get to check it out for a few seconds at a time. the front ten bolt concerns me to. but i have extra shafts, so hopefully they go first.
    as for drive shafts i have a high angle rear 1350s all the way thru. the front is box tube with crappy half ton joints(1310 i think?)
    now how do you suggest i get water in to and out of the tires?
  19. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    forget the water in the tires thing, too much hassle for what you would gain. Your going to pull a furd f150, not big foot. I bet you can beat him with the condition or weight your truck has right now as I type. Drop a little air, stick it in low low and wait for him to start hopping and romp on it. Drag him around for a few seconds while he keeps his foot in it or throws it in park and destroys something or actually has the sense to throw it in neutral once he knows its over for him.Walla you win. /forums/images/graemlins/thumb.gif
  20. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Hey mudjunkie, how much power are you making with that 540? I wouldn't mind pulling with you. /forums/images/graemlins/thumb.gif Maybe BB04'
