Axle Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by drofdar, Jan 23, 2006.
  1. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    Fresno, CA
    My Baja Runner has an older Dana 44 front axle with the enclosed knuckles. It has 4.56 gears and a Tru-Trac locker. I also have a newer Dana 44 from a 1973 Suburban. It has 4.10 gears.
    Question: Will the 4.56 gears and locker from the older axle fit the 1973 D44?
    Are the knuckles from the older (enclosed) axle suitable for use on
    a 1980 10 bolt front axle for a crossover steering setup?
    I have been told the knuckles from the 1973 D44 are good for use in a crossover system on the 10 bolt, but wondered about the older D44 knuckles.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    Sacramento, CA
    Depending on wether the D44 you have came from a chevy or something else, the only difference would be in Standard rotation versus reverse rotation.
    As for the knuckles, I could be wrong but you can't use closed knuckles with open knuckle outers.
    And I wouldn't think you wanna use closed knuckles with dinky shafts on big tires.
