Axle question
Discussion in 'The Garage' started by loonatic72, Aug 17, 2006.
  1. loonatic72
    loonatic72 Registered Member
    May 29, 2006
    36
    North Carolina
    I have a 79 k5 and was thinking of putting bigger axles over it, what would be the best combo to put under it that'll bolt up? Wont most 1 tons bolt up without shortening the axles? Thanks
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Well, the most coveted bolt-in combo swap is the Dana 60 front, 14 Bolt full floating (14bff) rear. These are direct bolt in.
    Keep in mind, the 14bff needs to be out of a 3/4 ton truck, otherwise the spring perches need to be moved. The axles (well, hubs) for a single reae wheel and dual rear wheel are different. The hubs might need to be changed, unless you are running wheels with a LOT of backspacing. Axles from vans are different lengths too. Driveshaft modifcation might be necissary too.
    It is a fairly easy and straitforward swap, as long as you have all the correct parts and basic hond tools and knowledge.
    Do some searching around here, as many of us have done this exact swap.
