axle question
Discussion in 'The Garage' started by MJF, Jul 25, 2002.
  1. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    This may be a stupid question for most of you, but I've never had a diff apart before.
    Is there a difference between the ring & pinion on a 3/4 ton & 1/2 ton? Are they interchangeable?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If you're speaking of the front 10 bolts and D44s, then yes, they are the same diff and shafts, differences are only from the knuckles out. </font color>
  3. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    I have a six lug d44 under my half ton &amp; an 8 lug d44 under my 3/4 ton. I was wondering if the ring &amp; pinion are interchangeable on the two. Like I said it is probably a stupid question that I could figure out on my own if I pulled them apart, but I'm not ready to pull them apart yet.
    If the gear ratio is the same, I want to pull the ring &amp; pinion out of the 1/2 ton &amp; put it in the 3/4 ton that has busted teeth. This should work right?
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yes, the R&amp;P are interchangable so long as they are on the same series carrier. You could just swap the carrier along with the R&amp;P though and everything would swap right over. </font color>
  5. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    That sounds good. I wish I knew what a carrier was though /forums/images/icons/crazy.gif
    I'm just kidding. Most of this stuf I'm seeing for the first time &amp; I'm learning as I go. Thanks for the info.
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The carrier is the thingy that the ring gear bolts to. </font color>
  7. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Did 3/4 tons come with 44's or 60's standard?
    I looked at the diff &amp; saw 44-?? on it the same as on the axle under my 79 &amp; 70 1/2 tons. Does that mean it's a 44? According to the descriptions of 60 &amp; 44, they are similar in apperance except size of carrier or something like that.
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> 3/4 tons came with the 44s. If you look on my Webshots page there are a bunch of pics of my D60 that should show all of the primary identifying marks on the D60. They do look similar, easiest way to tell the difference is 3 ways - D44 uses all ubolts to hold the axle to the springs, D60 uses bolts threaded into the housing on the inboard side of the passenger side spring; D60 has kingpins, D44 has balljoints; and then the number cast into the housing below and to the right of the diff cover, as you already mentioned. </font color>
