axle questions.. need verification.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by newboy89, Aug 1, 2002.
  1. newboy89
    newboy89 Registered Member
    Nov 18, 2001
    34
    Ny
    ok, i just got back looking at a truck.it's an 85 k20 with a complete 1 ton setup underneath it. sorry no pictures, couldnt get a digital camera in time. i looked under there and the rear axle looks like a 12 inch rockwell...the tag on the glove box door said that it had 4.10's and locking rears. i dont know what the front axle is, there was a plow setup and it was parked more or less on a bush so i couldnt get a good look. its got a 208 case and a turbo 400 tranny. 350SB.. pretty standard stuff as far as that goes.
    so the question is what is up with the axles. did they put a rockwell under there or am i mistaking it for an eaton? and what would the front axle be? thanks alot for the help.
  2. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    the k20 mostlikely came from gm with a 14 bolt sf and an 8 lug 10 bolt front.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    ok
    the axles have been swapped out for an unknown pair
    yet you still look to the door sticker to determine the possible ratios?
    whats a 12" rockwell? what 1ton did it come out of?
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'm with Marc...14 SF rear and an 8 lug 10 bolt front most likely.
    Rene
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Sounds like you might be talking about an Eaton rear - big round cover with 10 bolts, and a drop out center section. The Eaton rear was used pre-'73, and there was never a one ton 4X4 in those years, so if it is a matched pair of axles, the front will be a Dana 44. I would say that there is a very slim chance that you are going to find a Dana 60 under the front of that truck, but stranger things have happened.
