Axle Ratio Question
Discussion in 'The Garage' started by Old_Miner, Feb 13, 2006.
  1. Old_Miner
    Old_Miner Registered Member
    Feb 13, 2006
    9
    Idaho
    I have read in the forum in the past that if you rotate the tire one full revolution and count the times the driveshaft turns that is your axle ratio.
    I have an 1987 GMC Full Sized Jimmy (K5). I turn the tire one turn and the axle only turns 1.75 times. Surely that don't mean I have a 1.75:1 axle ration.
    There are no RP codes in the glove box and I wanted to find out the axle ratio so I can gear it for 35" tires.
    Any help will be appreciated.
    Thanks, Tom
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    You sure you didn't move it just a 1/2 turn (180 degrees). If you did, then you'de have ~3.5:1 gear ratio (brain fart on the exact number there)
  3. Old_Miner
    Feb 13, 2006
    9
    Idaho
    Nope, I turned it one whole turn. I double checked it several times.
  4. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Could try doing it the opposite way. Rotate the driveshaft until the tires turn one revolution.
    :dunno:
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If you are only turning 1 tire you need to multiply the Dshaft rotation by 2. With an open dif if only 1 tire spins it has to spin twice as fast. Have I confused you?
    Lets say you have 4.10s The driveshaft spins 4.1 times for each axle revolution. If you hold 1 tire so it cannot spin the spider gears will spin in such a manner that if the driveshaft spins 4.1 times the wheel that is spinning will spin 2 times.
    The ratio should be 3.08 or 3.73 if they are factory. I do not know if they offered 3.73 in 87 or not mine was 3.08.
    Ira
  6. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    get the numbers off the top of the axle tube near the center and call a dealership
  7. Old_Miner
    Feb 13, 2006
    9
    Idaho
    Yes, Totally confused
    Yes, It kind of makes sense.
    I spun the tire with both rear wheels off the ground and I noticed the other one turned the opposite direction, so I put that wheel on the ground so it could not spin.
    I spun one wheel and the drive shaft rotated 1.75 turns. So if I multiply that times two, I would guess that I have a 3.42.
    GM10-308 1258709
    3.08
    40-13
    $207.33
    GM10-342 1258710
    3.42
    42-13
    $207.33
    GM10-373 1259441
    3.73
    41-11
    $207.33
    Does this sound right? Also, who would you recommend me order gears from?
    I am thinking about going to 4:11 to turn 35" tires. Does that sound right?
  8. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    what tranny?
  9. Old_Miner
    Feb 13, 2006
    9
    Idaho
    700r4 NP208
  10. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    i'd run 4.56's...
  11. sandawgk5
    Oct 28, 2003
    6,881
    Anything with overdrive and 35 or higher I would run 5.13s.:D . Unless it is a 10 bolt then scrap it and put in a 14FF:D .
    Ira
  12. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    yeah, i know, i'm headed that route myself... shoulda put "minimum" after that..
    for the average every day DD joe asking, i figure 4.56 will keep the revs and fuel ecomomy reasonable and he'll still use OD.. plus i'm assuming he's talking about a 10b regear...
    i'm gonna run 36's with the 700 so i'm figuring 5:13's for myself, but i'm waiting on getting 1 tons..
  13. Old_Miner
    Feb 13, 2006
    9
    Idaho
    Yeah, I wish I could afford 1 tons, but I have the standard 10 bolt. If I do the gear change myself, I figure it will cost me around $500.
    If I get a shop to do it, they quoted me $1500.
    If I get 1 ton axles it would cost $3500.
    It sucks to be on a budget.
  14. sandawgk5
    Oct 28, 2003
    6,881
    If you do it yourself it would cost about $200 for gears and $100 for install kit it that per axle. The shop that told you $1500 could lick my nuts. Shop around. I have heard of guys getting it done for about $400 per at a shop. I did my 14FF and knowing what I know now I think I would have the patients to do my 60Front.:D There is nothing "hard" about it just takes a little time.
    Ira
  15. Old_Miner
    Feb 13, 2006
    9
    Idaho
    Only thing I have heard is that aligning and setting backlash can be hard. I guess I will find out.
  16. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Nice part about axles like a Ford 9" or 14bFF is you don't need to press-on/off the pinion bearing each time to change the shims, and carrier bearing use screw adjusters.
    Good axles to learn on. All the more reason to get the 14bff now rather than later. :D
    As for budget... last time I did rear brakes, I changed a whole axle instead... it was cheaper. :haha:
  17. sandawgk5
    Oct 28, 2003
    6,881
    It is not hard it is quite easy it just takes some patience and a little time to mess around with changing out shims and what not. Some guys get frustrated cause when you change pinion depth it effects backlash so you have to keep removing and installing shims. For those axles make sure you remove the bearings in 1 piece, then clearance the inside race so they slide on and off by hand. Now you have set of setup bearings. It allows you to change shims easier on the carrier and the pinion. The first step is to get your pinion depth set properly, then adjust your backlash.
    Ira
  18. Old_Miner
    Feb 13, 2006
    9
    Idaho
    Thanks for the good advice. Most excellent.
    I have been looking for a good how to article on change the ring and pinion, but have not found one yet.
