axle ratio stamping decode, KAH
Discussion in 'The Garage' started by R72K5, Mar 9, 2006.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    where how do you decode axle ratio stamping code ?
    KAH 1977 K-10 pickup 12 bolt
    google has been no help so far
    thanks for anything
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I dont know what KAH means, but why dont you just count the teeth on the ring gear and on the pinion gear and divide them together?
    -Harrison
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I've always wondered if you have ever tried to do this without removing the carrier. I don't know how you can?
    But the ratio should be stamped into the ring gear.
  4. 85k30
    85k30 Registered Member
    Jan 1, 2003
    24
    pull the cover
  5. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    Put it on a floor jack, block one tire on diffs with L/S or open carrier and spin tire one complete turn. Pinion will turn 3 3/4 turns for 3:73 or a little over
    4 1/2 for a 4:56.... etc....
    Rig must be in neutral :eek1: !
    Jeff
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeh theres always that way of checking it, but whe i do it it never seems ot come up right and them im still unsure and i am not ready to pull covers and change fluid yet but its on my list of to do things for this rig of course, as it should be for all rig owners
    i guess i will have ot call the chevy dealer counter in the morning or go out there and have them look it up
    seems that the internet has zero info on axle codes
    i was hoping that maybe by now there would be something, but i guess there isnt, nor ever will be
    i really hope the axles are 3.73 so i can dump the 12 bolt and put a common 14FF 3.73 under it
    it seems like it drives like 3.73 but im just not for sure, it just doesnt seem sluggish like 33" and 2.73 or 3.07 would be, unless its just the 400sbc working good,
    dunno
    *crosses fingers*
    thanks :D
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well crap its 3.07 ratio
    damn
    welp im just gonna keep the 33" tires and not put in an FF 14 bolt axle
    gonna remain a stock original K-10
    saves alot of work and $ i guess,
    just gonna be a daily driver, as it is right now and always has been
    it must not have really ever been wheeled much, as i checked the frame rail and its not cracked or anything, and theres no where to wheel here anyways, at all
    now to trim the fenders so the 33" wont rub anymore
    hmm
    thanks
