Axle ratios
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by horsepit, Jan 6, 2002.
  1. horsepit
    horsepit Registered Member
    Nov 25, 2001
    63
    Ventura, CA
    How do I find out what my axle ratio is on my 1987 Blazer with auto trans?
    Insearch of a Blazer.
  2. 73k20
    73k20 Registered Member
    Jul 6, 2001
    59
    South Louisiana
    There is a way to do it by jacking the rear axle up, spinning the wheel and count the revolutions of the driveshaft and/or wheel. Maybe someone else could give you a better explanation of how that's done, but the most acurate way is to remove the differential cover plate and spin your wheel until you see some number on the side of the ring gear. There should be a Mfg.date, make and Ratio numbers. Good Luck!
    Who said size doesn't matter?
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    But before you do ANYTHING....
    ....go to the glove box and look for the RPO code sticker in there. Read the codes and descriptions until you get to the "axle ratio" which will list the gear ratio.
    BUT, do not rely solely on the RPO code sticker. The ABSOLUTE best way to find out is to remove the cover and look for the stampings on the ring gear.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    some RPO stickers don't show the actual ratio, they show a series of three letter codes, find a site that lists RPO codes and find the code that corresponds with your gear ratio. most rear axle codes begin with G.
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
