Axle rebuilding
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Psycho, Jan 22, 2003.
  1. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    ok i am going to be rebuilding my 10bolt )3.73 gears) rear axle soon, i would like to know if anyone out there knows any tips and also some place to get good/affordable parts for this project any input will be helpful thanks...
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Here's the bext piece of advise anyone will ever give you about rebuilding your 10 bolt rear axle - don't do it.
    Not worth the time or money.
    -- Mike
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I think the cheapest place that I have found is Drivetrain Direct. Everything is fairly easy like seals and bearings but if you are planning on doing a gear swap I would say to shop around for a professional. I thought about it and tried to set the gears in my 14FF but lost patients soon and took it to ITP.
  4. wheelin_willy
    wheelin_willy Registered Member
    Jan 23, 2003
    24
    dtrivetrain direct is cheapest
    randys ring and pinion are the best
    its not too hard too don gears if you have the right tools
    you need;dial indicator on a magnetic stand
    pinion depth tool
    micrometer
    patience
    if you have these tools let me now if you dont plan on doing any other rear ends then take it somewhere but if you are its well worth the investment in tools /forums/images/graemlins/usaflag.gif
