Axle relocation options
Discussion in 'OffRoad Design' started by Derf00, Feb 5, 2003.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    My '90 Jimmy has a 6" BDS all spring lift, ORD extended front shackles, and 1" zero rates in the rear, and it sits level. I am now considering larger tires, 40 -42's, and am considering relocating the axles. What are my options for relocating the front axle and keeping is close to level?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I redrilled my spring perches and moved the axle forward. It seemed to work well for me. I moved it forward 1.25 inches.
  3. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    Is there any drawbacks doing it like that?
    /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Not that I have found. At first I was worried about strength issues but other people on the board rattled off some extreme trails that they ran with no problems after doing this mod. I decided to do it this way as I did not want any more lift in the front and it was a free thing to do. I could also move it back real easy if I ever wanted to. I've done some pretty rough wheeling and have not had any problems.
  5. 4x4_76
    Jul 22, 2001
    628
    Ylämaa, Finland
    With 1.25 inches,I guess stock driveshaft will work just fine with 3" lift that I'm getting?And probably steering adjustment?
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    The steering might be a trick if its stock. You might have to cut down the draglink ends to make up the space. dont know about the driveshaft. Every truck seems to be different on that one.
  7. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    I have crossover and have already had my front driveshaft modified for a 6" lift. Can I assume that moving the axle won't be a problem?
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I would think that you would be fine. I had the extra spline on my front driveline (12" spline) and now I show like 4 or 5 inches. If the mod cost any money I dont think I would have done it. It did help the tire to the firewall issue though. My tires stuff just fine now. /forums/images/graemlins/thumb.gif
  9. 4x4_76
    Jul 22, 2001
    628
    Ylämaa, Finland
    Thanks man,I appreciate your help /forums/images/graemlins/thumb.gif
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Good luck with it. /forums/images/graemlins/grin.gif
    Heres a pic of my tires moved forward.
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Hey Fred,
    How is everything?
    I moved mine forward the same way Sandman did, by drilling the perches and top plates. Very simple mod, and with crossover, your steering wheel will be off a little, but the drag link is the only other adjustment you will need to do. Here is a pic of mine with the 36"s. I have had no problems with this mod. I have 38"s on there now and have yet to rub the fender wells. I could run 40"s with no problem. My next tire/wheel combo will be 42"s with beadlocks.
  12. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I just did the A-Tron relocation block last weekend. I had him put a 3 degree taper on it, and the block was still about 7/8" tall...well, between the extra height of the block and moving axle forward 1.5", I needed to have the d-shaft lengthened. I too have a 6" lift. I had never lengthened the d-shaft prior to this, as when I put the D60 in, the extra pinion length allowed me to get away with the stock shaft. Not sure how much difference the 7/8" of lift made, most of it was due to moving axle forward. Everything looks to be fine with my crossover steering setup, no issues yet. Am gonna check out the drag link to crossmember clearance again when I go wheeling this weekend, looks like it will be ok, but we'll see! I sure hope this relocation helps the 38.5 SXs avoid major inner fender contact!
