Axle relocation
Discussion in 'OffRoad Design' started by JoseK5, Mar 12, 2002.
  1. JoseK5
    JoseK5 Registered Member
    Dec 12, 2001
    62
    Lebanon
    Any technical advice on any substantial benefit to axle relocation ie moving front axle forward and rear backward?
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Generally, it's an easy way (relatively) to get some extra fender clearance without doing as much trimming, when you add larger tires.
    The front tires will rub in the rear of the fenderwell as the shackle swivels back (under compression). Moving the axle forward a little can help get some needed clearance there.
    In the rear, the axle isn't truly centered in the wheelwell to begin with....as it "stuffs", it tends to hit the forward edge of the fender....so again, moving the axle AWAY from the problem area can be a solution.
    If you look in the photo gallery, you can probably see lots of pics which will show K5's "crossed up" and where the tires are trying to rub..... /forums/images/icons/cool.gif
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Do a search here, there are some other posts pertaining to this that would have good info for you.
