axle seal leaks on 14bff plesase help
Discussion in 'The Garage' started by crazykev4x4, Jul 15, 2003.
  1. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    i have a 14bff after new axles seals it starts to leak after about a week or so of driving this has happened twice now and im sick of them leaking all the time . i have the right install tool and i dont pound them in with a hammer like some people do i pound it in straight and even and i grease the seal and the spindle where it rides . anyone have a clue on how to stop this . my seal area is all clean and free of burrs and grooves . please help
    Kevin /forums/images/graemlins/k5.gif /forums/images/graemlins/confused.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    not sure why you're using a special tool to install seals, i know they have them...but a piece of 2x4 does the trick, never had one leak yet installing it that way...maybe because the wood gives more than a metal installer?
  3. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    it is a plastic install tool . ya the dam things keep on leaking .im sick of it
    Kevin
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Are You torqeing the hub's down to 50 ft.lbs. and then backing them off 1/4 turn to seat the bearing's?
  5. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    ya i am tourqing them but im not sure that would take out the seal if i was overtightning them but anyways they r tourqued to spec
    Kevin
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Good seal's as in Chicago Rawhide? C/R
    Or Schmuck's cheapie's? Ronco
  7. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    GM seals
  8. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Be sure the vent tube on the axle isn't stopped up. If it is, pressure will build up inside the housing and diff and instead of the pressure being relieved through the vent tube, it finds the path of least resistance (in this case the axle seals) and leaks gear dope in the process. Hope this cures your problem.
    Will
  9. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    vent is good and clear
  10. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    I think the 1st set i had on my 14FF did that too, but so far.. knock on wood, the 2nd set hasn't! /forums/images/graemlins/ignore.gif
    In doing the homework on it, i think someone mentioned that there's a super-thin sleeve that can be used to enlarge the axle flange surface just over the size of a gnat's a$$. That little bit makes the seals work mucho-better and no more problems. /forums/images/graemlins/thumb.gif
    Can't recall who mentioned that, but also think they were a tad pricey as well. Maybe it was the K30 guy? /forums/images/graemlins/confused.gif
    I miss my memory! Should you happen to see it, please send it back! I'd give a description, but i can't remember!!
    /forums/images/graemlins/rotfl.gif
  11. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    i have been trying to find a sleeve like that and havent had much luck . if anyone knows about it please post the part number
    Kevin
  12. nvrenuf
    Jan 7, 2002
    13,082
    250
    Mobile, Al.
    The C/R brand sleeve for a 14 bolt is #99282, I got mine from Motion Industries. I was also able to get a CR seal by cross referencing the National #, the CR seal was a much better seal - double wall & double lip. Sorry, I don't have the CR seal number.
