Axle Shaft leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, May 15, 2001.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    <font color=red>I have a 10 bolt axle, and gear oil is leaking out of the passenger axle shaft. What could be the problem and how hard is it to fix.</font color=red> <font color=blue>Aslo does any one know the part # for the bushing that needs to be replace to stop the leak at the slip yoke on a 208 transfercase?</font color=blue> [​IMG]
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    It's not too bad of a job. Most any repair manual will cover it. Basically, you put the rear on jack stands, take off tires, brake drums, and differential cover. There will be a small bolt or pin holding in a 'cross shaft' that the spider gears ride on in the diff. carrier. take that bolt/pin out, remove the cross shaft and push in slightly on the axles from the tire end of them. You can then pull out the 'c' clips from the axle ends in the diff. carrier, then pull out the axles. The seals and bearings are just inside of the tire side of the axle tube. Pry out the old seals and replace with new. Inspect axle where bearings run for worn or pitting. Either is bad. Might as well replace bearings while you're there. They can be tough to get out. Rent or borrow a bearing puller from the parts store. Install reverse of removal.
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sorry forgot to say front axle
  4. Should be the same, but you take off the front rotor instead of the brake drum.
    '84 K5
    Chevy in my blood.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The front end is a way bigger job. The axle seals are at the differential end of the axle. You have to pull the diff out of the housing to get to those seals. [​IMG] To get the diff out, you have to remove both axles. To remove the axles you have to pull the calipers, rotors and spindles. [​IMG]
    There's probably some dirt caked up inside the axle tube, that chewed up the seal. You should clean out the tubes extremely well before you reinstall the axles or you'll just push more dirt into the new seals.
