axle shaft movement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Oblin Goblin, Jun 3, 2002.
  1. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Is it ok if the axle shaft on a 12 bolt moves in and out a little? I was looking over a used 12 bolt I bought yesterday and I noticed that the left side axle shaft can slide in and out about 1/16". The right one doesn't move. Is this a problem? If so how do I fix it?
  2. tagurit
    tagurit Registered Member
    Mar 19, 2002
    25
    Nth E. Louisiana
    I have this same problem. I thought there was a "bolt" to keep it from doing this ??
    It only does it on the front left of my ride. This is also the only side that gets coated with PS fluid due to a leaky PS gearbox but that shouldn't matter...
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    That is normal. If you are seriously worried about it, you can pull the cover and inspect the ends of the the axle shafts where the C-clip fits in and make sure it is not shearing (not likely) and also inspect the cross shaft. With only 1/16'' movement I wouldn't worry about it.
  4. tagurit
    Mar 19, 2002
    25
    Nth E. Louisiana
    I just read the first post again and that isn't the problem I have.
    What I have is the axle tube (part that ties into the leafs) is sliding back and forth. I thought their was a bolt, or pin, to keep the axle from moving?
  5. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    tagurit: There is a bolt that goes through the leaf pack and the head of it will fit into a hole in the spring perch to keep the axle in place. It is very easy to replace and very cheap too.
