Axle shaft question
Discussion in 'The Garage' started by protechk5, Jan 17, 2005.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    I got a blown 1990 10 bolt rear with the 30 spline shafts right, i got the rebuild kit and new gears to go in it but i still need a carrier. But i have a old front 10 bolt that is pretty old so it has 28 spline shafts, so would that front carrier work in my rear? or does the shafts connect to the carrier?? Get what im saying??
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you'd have to swap side spider gears. Which are likely broken(they are notoriouslly weak). Either that or get 28 spline shafts for your rear. The 30 splines are stronger but its still a 10 bolt, they will still break, so 28 spline is the better option cause the shafts are much easier to get your hands on.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The 30 spline carriers are notoriously weak which apparently you have learned. 28 spline carriers are stronger but the spider gears are weak. Front carriers will swap to the rear and vise versa. The best option I think is a 28 spline carrier, 28 spline shafts, and a traction device that will replace that spider gears.
    Harley
