Axle Shaft Questions
Discussion in 'The Garage' started by AZ79K5Project, Feb 4, 2007.
  1. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    I am in the process of swapping axle shafts and doing crossover. I have searched my service manual and have come up dry. I have a couple of questions. There are a couple of differences between my new (chrome moly) and spare axle shafts. (28 spline 10 bolts)
    What do you call the the gasket/seal that sits at the end of the shaft - wtf is it? Is it the dirt shield? Arrow #1...
    The new axle does not have the large sized shield at the very end of the shaft. It is welded to the old shaft .. (Arrow #2). Is there something missing or just different designs?
    Edit: One more pic. I moved the gasket/seal away from the end of the shaft for the pic:
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    the rubber seal, iirc, is just the dirt seal like you said, the metal ring, iirc, is just another type of the same thing, just swap the rubber, and put it together.
  3. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Got some answers
    I went to 4 Wheel Parts today and I got an exploded view of the D44 axle. The exploded view has a spacer listed (part 51). I have never seen this in any axle that I have pulled apart. Anyone.
  4. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    #48 - Slinger -- Spindle Yoke.
    This is on the list in the previous post. I bought this in a set from NAPA. It comes in a spindle seal kit. It is not welded on but pressed on. I hope this helps you.
