Axle Shaft/Ujoint question
Discussion in 'The Garage' started by TXsizeK5, Sep 6, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I was reading this month's peterson's 4wheel mag and I read about the CTM ujoint and axleshafts... it says its for a D44, would these be interchangeable into a 10bolt?
    If so, i wouldnt have to worry about breakage on shaft and joints... so then i'd have to watchout for carrier breakage?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    At that point the very expensive to replace ring and pinion become the weak part of the torque chain. /forums/images/graemlins/eek.gif /forums/images/graemlins/frown.gif I think it was Shaggy that blew 3 ring gears after upgrading the shafts, before finally going to a Dana 60. /forums/images/graemlins/shocked.gif
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    U Joint would be interchangeable, but you would have to order 10b axle shafts.....
