Axle Shaft
Discussion in 'The Garage' started by cegusman, May 1, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Is there a difference between a 1/2t vs a 3/4t dana 44 axle shaft?
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    No, theres not, the only difference between 1/2 & 3/4 ton fronts (assuming we're comparing same years and axels) is the hub and brakes.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    The only change GM had to the D44 axelshafts was in 1972 going from the smaller 230 Ujoint to the 297Ujoint.
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    OK thanks, As soon as I get off of work I have to pull two axle shafts
  5. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Don't you mean from 260 u-joint to 297 u-joint?
  6. What about Corporate 10 Bolt fronts, is there any difference between the 3/4 and the 1/2 ton models? I have heard that the 3/4 tons ones are stronger, and are the same as the Dana 44HD is this ture? Thanks 80K20
  7. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    A 10-bolt is a 10-bolt. Only differences that ever occurred that I am aware of are the spline count change from 28 to 31 (or is it 30). I didn't know they put a 10-bolt in a 3/4t. if they did, then it probably has 8 lugs on it as well.
  8. Burt4x4
    6,854
    Yup it's the spline count in a 10bolt 28 or 30. 30 being the stronger of the two...
  9. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Yea, all of you mid 80s 3/4 ton trucks and Burbs had 10 bolt fronts.
    Dan
  10. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    As far as I know all 3/4 tons had either the Dana 44 or 10 bolt in it.
    What else? Dana 60s were on the 1 tons only. I am sure there are crazy exceptions, but generally.
    Ken H.
