Axle shimming - 2 degrees in which direction?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OneInTheSun, Feb 6, 2002.
  1. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    I know it's good to have the driveshaft angles one or two degrees apart from one another to negate any axle wrap induced vibes. So, in relation to each other, should the pinion angle be 2 degrees greater or lesser than the t-case angle?
    <font color=blue>Rob
    85 K5</font color=blue>
    [​IMG] 24 beers in a case, 24 hours in a day - Coincidence?
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    As far as I know, you should have the pinion angled DOWN 1-2 degrees to negate the effects of axle wrapup under load.
