Axle shims and safety
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by morphed86k10, Jul 29, 2002.
  1. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I'm considering some Hill front shackles to get a little more clearance when swap my wider wheels on. I'm going to put either 36" TSL Radials or 37" SSR's on my 16x10 rims. Looks like a shim will be required, and I want to know if there is any drawbacks to using a small shim on the front axle?
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    As long as it's not more than 4 degrees or so you should be fine. A local spring shop here sells the little collar washers for the center bolt. It helps the head of the center bolt protrude far enough into the perch hole when using a shim.
    Don't stack shims either...
    Rene
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My 4" Rancho kit came with them. I re-used them when I installed the 6" springs I have now. They're 2.5*.
