Axle shims w/ shackle flip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Oct 9, 2002.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    After some great advice from ya'll I'm going with the shackle flip (not sure which one yet).. so when I do this and ditch the blocks what degree, if any, of a shim will I need with a 4" lift.. transfer case not lowered.. Thanks again folks /forums/images/graemlins/ears.gif /forums/images/graemlins/k5.gif
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The most common for the K5's have been between 2-4 degrees depending on which transfer case your running. There are other irregularities which can skew it of a degree or two between similar setups.
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    is echobit coming out with axle shims?
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I bought some 8 degree shims from Roger and they were not the same thickness. He cuts them using a band saw and the accuarcy of the cut is not exact.
    This place also sells steel shims.
  6. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    No, I still buy them like everyone else.
