Axle spline count
Discussion in 'The Garage' started by K5Steve, Oct 31, 2005.
  1. K5Steve
    K5Steve 1/2 ton status
    Aug 10, 2005
    288
    Carson city, nv.
    I am having my rear end rebuilt and it's a 10 bolt with 3.73's.My carrier is broken and the axles are worn.The guy at the shop first said it was a 29 spline count but I told him it was either 28 or 30.He recounted and said it was 30.Now I am buying a new eaton posi carrier and new axles,my question is if the axles are by chance 28 count and I get both the axles and carrier in a 30 count would it hurt anything?
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    The axle shafts just have to match the carrier. The gear will interchange. I you wheel the truck 28 spline would be a better choice because replacements are plentiful, but thats just my .02cents. I ran 30 spline fronts in mine and always had a hard time finding replacements when I needed them and people usually wanted more for them.
  3. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    I don't do too much wheeling but do go out.Which one would be stronger,28 or 30?
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I'd say the 30 spline prob. but neither compare to D60 shafts. Again, if I had it to do over again I would run 28spline. Only reason I went with 30 spline was because I got a good deal on a 30 spline limited slip unit for the front.
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Also I think 89 was the first year they used 30 spline in the front. Yours is an 88 right? I think 88 should be 28 spline.
  6. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    Right,it's an 88.I just ordered the 30 spline carrier and shafts but it's a retail pickup order from summit so I can change it.Nobody had 28 spline shafts on hand but summit had 30 spline everything.$847 for an Eaton posi,install kit with axle bearings,and superior axles.
  7. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Ok your golden. I just realized that you were talking about the rear.
