axle spring pad needed..
Discussion in 'The Garage' started by skidpan, Apr 3, 2007.
  1. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    I am putting a set of full size axles under a 79 scout II, but the spring pad ( is it called that) on the chevy axles needs to be moved in a little bit.. I dont really want to grind off the old ones and attempt to reuse them. Is there a place I could buy a set?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Nearly every speed shop , axle builder , and fab shop has em on hand .
    I have even seen bolt on ones , but that isn't to be used where the springs also locate the axle .
  3. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
  4. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    edit: d'oh! obijuan beat me to it.
    scroll past halfway on this link. they have a set for 14 bolt: http://www.diy4x.com/suspension.htm
    i'm sure they'd fab some for other axles, too if you asked.
    ord and blackwidow performance may also have something, or be willing to fab it.
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i got mine from dan at www.ruffstuffspecialties.com as well as other fabb'n parts
    i am almost finished doing the same thing
    just need to put the front back togather and redo the front driveshaft.
  6. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    I got mine from diy4x and they are rediculous! Will be putting them on this weekend. i initially had some other crap ones on there from Ebay or something and they started to collapse after less than 2 years
  7. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    that looks cool, scoobydannn. if i ever had a jeep or other small 4x4, i'd want to do something just like that.
  8. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Huh huh, PAD.
