Axle Swap Help!!!!
Discussion in 'The Garage' started by t89blazer, Sep 20, 2006.
  1. t89blazer
    t89blazer 1/2 ton status Premium Member
    Jan 16, 2005
    677
    Jackson, MS
    I just bought a CUCV and am planning on doing an axle swap on my 89 K5:D . Currently I have a 700R4, 241 and 10 bolts. I have a Rancho 4inch lift with 35 inch tires. My question is will I have to lenghten or shorten my driveshafts? I have stock shafts front and rear with a slip yoke in the rear. I think I read somewhere that the longer pinion on the D60 and 14 bolt will make up for the lift and basically move the shafts back where they need to be (give or take). I am planning on having new shafts made, but I only want to do it once. I am in the process of building a doubler, but would really like to install my new axles now if possible.
    Thanks for the help,
    Tim
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have a 700 with 208 and I still run my stock shafts after I removed my 10 bolts and installed a 60/14FF combo.
    Ira
  3. t89blazer
    Jan 16, 2005
    677
    Jackson, MS
    Do you have any fears of the rear shaft bottoming out and breaking the tailhousing of your tcase? Thanks for the quick reply.
    Tim
  4. sandawgk5
    Oct 28, 2003
    6,881
    Nope I have wheeled it and had no damage at all. I also dont jump it either:D .
    I got no damage from doing this.
    The front is compressed as far as the axle will go and the rear is dropped out as far as it will go.
    Ira
  5. t89blazer
    Jan 16, 2005
    677
    Jackson, MS
    Thanks for the help Ira (NICE PICS), anyone done this with a NP241?
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yep, me 2 times. First with my 89 then my 90. I am still running the stock front shaft on my 90 now.
  7. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    i got a custom lenghtened shaft made for my 6" lift going to my 10 bolt front. it was too long when i swapped my D60 in. 700/208 combo
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    the pinions on 60 and 14 are longer so with lift they fit perfect.
