Axle swap.. need help Please !!! Installed 12 bolt rear.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Dec 23, 2001.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Just installed a 12 bolt rear and lift in my 89 Blazer..
    Well the universal joint from my 89 is too big for the YOKE on the 12 bolt.. what option do I have to rememdy this?
    I really don't want to put in the 10 bolt again.. is there a u-joint like the 447 that will work for this application?
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  2. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Are you having problems already? You never called me either turd! Can you get a driveshaft from harolds or Austin Drivetrain? Pricey but works! Any other ideas? Ask K30Guy!
    <blockquote><font class="small">In reply to:</font><hr>
    <font color=red>My Wife:</font color=red>"Only two minor cosmetic problems: The inside and the outside!"
    <hr></blockquote>
    1972 K5 6.5L,465,203/205Doubler,14FF/D60
  3. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    I used a NAPA #248 when I did my conversion. It should work for yours to. Get a spare. NAPA im my area does not stock this normally.
    Kent
    1989 K5
  4. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Bruce.. sorry... I got started early... Couldn't resist finishing..
    I found out the yoke on the 12 bolt is smaller than the 10 bolt.. that's the only problem I ran into..
    Kent.. thanks.. sounds like my truck and your truck are identical setups.. thanks for the quick response.. Off to Napa I go..
  5. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    I had the same problem I believe the number for that u joint is 348 at napa Ive ha to buy two of them they arent cheep I got mine for $27 a piece after my shop discount more like $36 if i didn't have a discount I dont know if i helped an but happy wheelin and don't forget to break something HA HA HA [​IMG]
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  6. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    When I did mine I beleive I reused the yoke from the 10 bolt . All you should have to do is get a different oil seal. I think its also for a 10 bolt I can't remember. But I can check if you want.
  7. Grim-Reaper
    7,385
    Atlanta
    You can reuse the 10 bolt yoke. 10 bolt runs a bigger U-Joint than a 12.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  8. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    Do you have a part# for that seal?
  9. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks guy's.. Napa gave me part # 372
    Worked great... I didn't know if you could re-use the 10 bolt yoke.. I couldn't get the yoke off the 12 bolt.. thing seem's like it's welded on.. Tried Impact wrench and breaker bar.. no go.
    Anyway's.. truck is done.. 12 bolt w/ Auburn limited slip in it and 4 inch lift w/ 33 tires.. man it look's so different..
    Thanks for all your suggestions.. I'll have pics posted tomorrow.
