AXLE SWAP PROBLEM
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TB2Blazer, May 14, 2003.
  1. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    Ok here is the deal I'm putting a 14ff in my 85 K5 and so far everything has gone pretty smooth. I have finally come across the problem of my driveshaft u joint from the blazer does not fit the pinion yoke on the 14ff. How can I fix this? Can I pull the pinion yoke off of the old 10 bolt and put it on the 14ff? I tried going to autozone to find a u joint that would fit both and I couldn't find one. Is there a special u joint that I can put in it and if so who makes it and where can I find one?
  2. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    napa has the part, dont know the part # but the u-joint is 1310/1350, correct me if Im wrong.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You need Napa #447 - that's a 1330/1350 combo. /forums/images/graemlins/thumb.gif
  4. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    they all have the right part autozone, orielly, advanced auto. just tell them 1350 w/ a 1310
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    they won't know what the hell you're talknig about at Advance for sure. best bet just get a new yoke on the driveshaft welded on, for me it was only $15 for the yoke plus having it welded on. i think he may have screwed up though /forums/images/graemlins/grin.gif
