Axle swap Question
Discussion in 'The Garage' started by mudbog42, Dec 22, 2006.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    I want to get a 14 bolt on my 86 k-5, would it matter what year truck I took it out if I was to reuse my same springs so that I wouldn't need to move my perches?
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    No0b......did you use the search before you posted this?
    Any 3/4 ton 14bff will bolt in.
  3. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Can't search yet, but it has to come out of 3/4 ton
  4. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    It doesnt HAVE to....the differance is the perches, 1 ton are spring under and 3/4 are spring over. If you get a 3/4 the perches line right up. The only thing to think about is your E-brake.
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Spring under?? Only truck that I've seen that was spring under was an S-10. 3/4 ton has the right perch width, 1 tons use a narrower perch, but can be cut off and new perches welded on. Easier to get the 3/4 ton. Get a conv. joint, maybe shock mounts, dunno bout e-brake, never had any that worked.
  6. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    I think he means the u-bolts point down instead of up.
  7. mudbog42
    Jul 16, 2006
    452
    Florida for now
    What years are compatible with these trucks?
  8. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Yes, that is what I mean:thumb:
