Axle swap question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Dec 7, 2000.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Is there anything hard I'm forgetting about? This job sounds pretty straightforward to me. Taking the Dana44 and 12bolt in my Blazer and putting them in a friends 1991 K5 to replace the 10bolts.
    New yokes maybe? Will the brakelines attach the same? Anything else?
    '73 K5
    Chevy good...Ford bad
  2. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    I do believe you will have to change the front lines,i think the back is the same(I think).I believe the 12 is a perfect fit,including the universal.I too would also like to know if the d44 will be a strait replacement for the 10.Like will the steering arm/draglink fit?Spring plates?U-bolts?Front driveshaft yoke?I will be changing my front 10 to a 44 soon too i hope.
    One From None
  3. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I currently have a Dana 44 in my 74 Blazer. It is a complete bolt in. I reused the same u-joint and the same front leaf-springs. Brakelines even were the same as the 10 bolt. More or less it is a easy upgrade.
    Communication Breakdown
    74 Blazer
    Zeppelin
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Everything is pretty striaght forward and the front brakes lines will be fine.
    The only thing I can think of is on the 12 bolt. Some 12 bolts came with a "small" u-joint. If yours has the small u-joint then you need to swap yokes for the larger one. But if you have the large u-joint on it already you are lucky! :)
    You can swap the 10 bolt large u-joint yoke onto the 12 bolt but will need a different seal and I am not sure what the part number is off the top of my head.(I htink it is just the 10 bolt seal, but not 100% sure)
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Zepplin, why did your '74 have a 10-bolt in it? Had it been previously swapped? 74's came stock with a Dana 44 up front. 10-bolts started being used midway through the '77 model year.
    http://ThunderTruck.ColoradoK5.com
  6. CK5
    May 19, 1999
    21,622
    701
    CO
    You may need new brake lines, when I did this swap on my 90 K5, the caliper side of the brake line were different from the 10 bolt, GM may have switched things around from year to year, I have a axle swap article in the tech section.
    Steve
    1990 K5 with stuff
