Axle Swap
Discussion in '1936-Present Suburban' started by chadwinstead, Apr 20, 2005.
  1. chadwinstead
    chadwinstead Registered Member
    Apr 20, 2005
    6
    San Diego, CA
    I have a 1987 Suburban, I'm trying to do most of the work myself and learn what I can. I desided to swap axles to dana 60 front and rear. My problem is that the forword pumpkin on the dana 60 is set to the driver side and the stock pumpkin is to the passenger side. Can this conversion be done? Can someone give me an idea of what I'm getting into and where to start?
    Chad
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You have 2 choices on this:
    1 - Sell your front ford D60 and buy a chevy or dodge D60 with the passenger side drop
    2 - buy a different tcase which will put your front driveshaft on the drivers side for the ford D60
  3. chadwinstead
    Apr 20, 2005
    6
    San Diego, CA
    I am probably go with the tcase. Any good sugestion to start? Stock tcase or is there somthing better out there? I also want to incorporate an ebrake on the tcase.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If your looking to case a driveline ebrake, then go with a 205
  5. chadwinstead
    Apr 20, 2005
    6
    San Diego, CA
    Thanks. What do you think of the "doubler" tcase?
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    They are good yes, but if your going to use your current D60, you'll still need to get a Ford tcase.
  7. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    in addition to the case youll need to most likely fabricate a crossmember for it unless you can find a x-member thatll mount a ford case in a gm truck...
  8. chadwinstead
    Apr 20, 2005
    6
    San Diego, CA
    Thanks for the advise.
