axle swap
Discussion in 'The Garage' started by 454silverado, Jul 23, 2005.
  1. 454silverado
    454silverado Newbie
    Jul 23, 2005
    wisconsin
    I have an 85 chevy 3/4 ton silverado with a 4in suspension lift, 3in body lift, 454, TH400trans, and a NP 208, 2. something ratioT-case. There's a 14 bolt 9 1/2 in the rear and i'm not sure whats in the front. I wanna swap in a corp 14 bolt in the rear and a 1 ton dana 60 in the front. I've read you have to get special u joints for this and i might have to move spring perches. I've also read that 15 in rims wont fit on the rear. what gears should i run with 35 in tires? i was thinking 4.56 front and rear would be okay? Is the NP 208 up to the challage or should i find a np205 or 203. any other info, suggestions would be greatly appreciated. thanks in advance.
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    if you have a solid front axle then everything should bolt right in! and as far as u-joints go they do make a conversion joint but you would be better off taking your drive lines down to the shop to get built for your truck,but you must decide which t-case your gonna use first , If you cant afford an Atalas then go with a fixed yoke np205!! As for the rims, you will need 16's or bigger but i would go with a 16
  3. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
  4. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    True you can shave the calipers but if they ever go out on a trail have fun grinding them down in the middle of nowhere........just my suggestion
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am not quite certain what you mean but I dont think I have ever heard of a reason to change a caliper on the trail. Am I missing something? Also does anyone carry a spare caliper with them on the trail?
  6. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    1 time my buddy and I were wheelin and he came down pretty hard and broke a front caliper but im sure its pretty rare. Im just saying its something to think about thats all :D
